Measure with tape measure. Or if buying ask seller to get tape measure. Or if buy new one to replace model gone for disposal, measure the space available.
All fairly standard size anyway unless 'compact' model.
Basic measurements for washer and dryer with door closed and not on optional pedestal(s) are 31.5" deep (front to back), 27" wide, (left to right), and 38" high. For installation and usage consider the leveling feet, use of pedestal(s), water hookups, drain hose for washer, and vent (exhaust) hose for dryer. You may want to position the washer on your left, and the dryer on the right due to hinge location, and for ease of transferring laundry from one machine to the other. Depth of washer (front to back) with door open 90 degrees is 50.5" and the dryer is 51.5". At the factory, four (4) shipping bolts are attached to the back of the washer to secure the drum for shipping. These should be re-installed prior to the move, (if you still have them). To see the supporting documents, go to; http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/ewpl_mic_604_021.pdf
I hope this helps you as well as others. Please rate my answer. Handiest1. 10-1-10
If you call fridgidaire support they will be able to tell you all you need to know about size or dimensions. The number is 1-800-374-4432. also if you want you can just measure the widthlooking at the front. depth. Front to back (side of machine) and height. If you write down those dimensions along weather it's gas or electric and the model numbers. You shouldn't have any problems at whatever store you go to. I hope tis helped you out. It would be greatly appreciated if you could rate my answer. Thanks, MIKE-
Under the counter dish washers are very standardized. Just measure the current counter height and width of the opening. Nearly everything will fit unless it's a special order. GSD500G install dimensions are available on-line. Just Google the Model Number.
