We have a Maytag side by side refrigerator. Our freezer side is leaking water inside which causes huge blocks of ice all over our food. I'm sure it's the ice maker, because some of the ice cubes are hollow and there are ton of isicles from the bottom of the ice bin. Any advice on how to fix this?
Make sure the water is coming from the ice maker by using additional light to spot the source of the leak then you possibly have a defective water fill valve leaking water slowly and causing water to freeze where water exits the tube into the ice maker. Once there is ice there and the ice maker calls for water the water either spews all over everything or is blocked from filling the ice maker cube slots altogether. The only repair is to replace your=> Whirlpool Refrigerator Water Inlet Valve W10408179
I'm here on Fixya if you have questions Contact Me Here
Ome cause might be water from the ice maker is over flowing caused by 2 problems: 1 it could be a wrong calculation of water from your ice maker electronic board or 2 water solenoid to your ice maker is leaking .
Please look around your refrigerator fresh food section door frame for a model number. I believe the reason water is leaking inside freezer is a defective water control valve that you attached to with water line on back of most refrigerators.
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
check to see if the water tube is all the way in the ice maker
