SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo
Stamp uses.
Follow these steps to correct
it
Step 1: Download Microsoft Windows Installer CleanUp
Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2.
Save the file on the Desktop.
3. Please double click the msicuu2.exe file to
install it on the computer.
Step 2: Remove .NET Framework
1.
Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please
locate and remove Any .NET Framework 2.0 software.
After that, please
perform the following suggestions to reinstall .NET
Framework 2.0 and its
updates.
Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please
download and install the following
Microsoft .NET Framework 2.0 Service
Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note:
When the "File Download" window appears, please click Save, and follow
the
directions to save the file on the Desktop. After downloading all the
setup
files, please double-click on each one to install them.
SOURCE: DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
Unplug the printer and wait 30 seconds then plug it back in. Mine printed everything that was in the queque.
SOURCE: dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
SOURCE: dymo labelwriter 400 not recognized as a usb
Tossed it and bought a new on. Even Dymo couldn't help.
SOURCE: Dymo labelwriter 400 Turbo -We replaced the roll
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. Use quality Dymo labels.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
