Right front wheel becoming very hot when driving
Also notice slight 'tug' to right when release the steering wheel
Can feel resistance to rolling when free wheel or change gears
This morning had a slight shudder in the steering for a short while
Suspect that the brake pads are not clearing the disc
Thanks all for the feedback
The piston on the calipers is very stiff - was very hard to retract
Is it a common problem for the piston to stiffen like this...?
Hoping that lubricating the piston or replacing the seals will solve it cause a new calipers is looking expensive....
I too have had this. In my case it was caused by the flexible hose expanding internally and acting as a valve, allowing fluid to pass to the brake but not return.
It sounds like the caliber is not work proply get it check out so as you can. you can start a fire and the brake will ware down very fast and you may lose you brakes!!!!!
Sounds like you accurately diagnosed the problem. You didn't mention aany grinding noise so it sounds like a sticking caliper, Remove wheel, spray piston with disc brake cleaner.
Also inspect pads for wear and rotor for scratches, grooves. If pads thin, or rotors damaged, find a mechanic.
If cleaner doesn't free the piston, you should, again, get mechanic to check it out.
Hi i had new front pads fitted at dealers at 88000 ks and about 6000 ks latter one pad on each front wheels are worn out the other side on each wheel are showing almost no wear i was towing our van but only for about 3000 ks max hope you can help
regards Ken
The steering is fine and shudder doesn't occur when making right turn.
