Copiers
Problem for Copiers
Generic problem for all Copiers
Configuration of LAN fax
By blueshirt on Oct 09, 2007
How do I configure LAN Fax on a user's workstation?
Best Solution
posted on Nov 05, 2007
Helpful)
Kemo
Rank: Guru
Rating: 88%, 97 votes
You must have Lan fax drivers for Your machine.
I dont know which type of machine You have.
1. Connect Your machine in network.
2.Install Drivers for LAN Fax( same procedure when installing new printer. You must choose new port,TCP IP port an enter IP adress of Fax. Then probably You can open home page of your fax in ie browser when enter IP adress, and configure it.Or find some configuration utility for your fax if already connected and installed.
Was this helpful?
Yes
No
Solution #2
posted on Nov 19, 2008
Not Rated)
docusultant
Rank: Wiz
Rating: 84%, 17 votes
The best solution I use is Smart Net Monitor, which is supplied with the Ricoh disks or can be downloaded from www.ricoh-usa.com . First you need to install the lan fax driver, after that then install Smartnet Monitor.
From there click start, and then control panel, then printers and faxes, then right click on the Ricoh LAN fax driver, from there click properties, click ports, then click add a port, under available ports you will see smartnet port (highlite) and then select new port, a new box will come up and then select search, the software will then make the connection and add the port. Besure to click ok and apply and then you are connected
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
I need a user's guide or manual for an NEC IT 5035 KX
Answer
My Fax copier sacner leaves a thick black line down one side of the paper
Answer
why is copier printing black after cartridge changed?
Answer
I have a p touch 1100QL. It jammed and I do not know how to feed the tape to make it print again.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copiers Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
