SOURCE: what is the firring order for 2006 Cadillac cts
Firing order 1-2-3-4-5-6 ------- front | 1 3 5 | of | | vehicle | 2 4 6 | ------- distributorless ignition NOTE THIS IS FOR THE 3.6L
SOURCE: 2003 Cadillac CTS - the car won't shift from park
sounds like you have a bad brkae light switch, which is located on the brake pedal assembly. a bad switch will not let you shift out of park and you will not have any brake lights as the car does not recognize that the pedal is being pushed and brakes engaged. easy to replace switch if you are handy, if not this is a inexpensive repair at any mechanic. hope this was helpful is so please rate 4 thumbs.
SOURCE: how do you control the dashboard lights in a 2006 cadillac cts
How can I increase lighting on the dash control panel in a 2004 Cadillac CTS
Whenever
this warning light or any other stays on in the dash it is indicating
that the systems control module (or the system sensor in the case of
lights like low oil pressure, door open indicators etc.) has detected
a fault, it then disables the system (this applies to ABS,TCS, TCM,
SRS, TPMS, MIL, CEL and BCM faults and others) as long as the light
is on. You must now have the dealer hook up a special electronic
diagnostic tool and "scan" the system for the fault code
that is stored for the problem(s)
Legend of Abbreviations. ABS Anti-lock brake system. TCS Traction control system, TCM Transmission control module, SRS Supplemental restraint system, BCM Body control module. TPMS Tire Pressure Monitor System, MIL Malfunction Indicator Lamp, CEL Check Engine Light.
