Did you get any error messages? Since the BIOS is available, the problem is likely with the hard drive or it's trying to boot from non-bootable media (DVD, flash drive, USB connected floppy/hard drive). Since you can access the BIOS, look for the Boot Selection Order and make sure that the hard drive is first in the list. If the BIOS doesn't see the hard drive, it may be bad or have a bad power or data connection. (You can try opening the computer and reseating the cables - see Asus for any assistance. I am not informed on opening the F9e.)
If the hard drive is seen by the BIOS:
Disconnect any USB devices (and the optical disc if it is in the drive). Turn off the computer. Unplug the notebook from the power supply and remove the battery. Wait 10+ seconds (or a few minutes) then reconnect the battery and then the power brick. Try restarting the computer. (This is a hard reset.)
What do you see on the computer screen? If you see a blinking cursor, the computer doesn't have the boot manager available (either corrupted or a new disc that hasn't had the OS installed). Use a Windows install/upgrade disc/system repair disc for your OS version (the service pack must match) or a third-party disc management tool to attempt to repair the boot manager.
You will need the optical drive as the first boot device in the BIOS or press Esc to access boot order list. (On some computers, it's F12.) For Vista or Win7, boot from the CD and follow the on-screen directions until you see a list of choices. If the hard drive was previously working, click on Repair your computer. Select the OS to repair then click Next. Select the Command Prompt option. Type in bootrec /ScanOs to get a list of available Windows OS versions on the hard drive. Use the command bootrec /FixBoot to fix the master boot record. The command bootrec /RebuildBcd will rebuild the list of Windows OS versions. See
http://support.microsoft.com/kb/927392 for details.
Installing a new hard drive and reinstalling the OS may be needed if you have a SMART or AHCI/SATA hard drive error. If you have a back up image, you may be able to restore that image.
I hope this helps. Please add a comment with any error messages for more assistance.
