My Asus F9e doesnt start anymore. i dont know what to do. i can open this BIOS but dont know what to do in there. Please help me! kind regards Peter (64) - SWITZERLAND
Did you get any error messages? Since the BIOS is available, the problem is likely with the hard drive or it's trying to boot from non-bootable media (DVD, flash drive, USB connected floppy/hard drive). Since you can access the BIOS, look for the Boot Selection Order and make sure that the hard drive is first in the list. If the BIOS doesn't see the hard drive, it may be bad or have a bad power or data connection. (You can try opening the computer and reseating the cables - see Asus for any assistance. I am not informed on opening the F9e.)
If the hard drive is seen by the BIOS:
Disconnect any USB devices (and the optical disc if it is in the drive). Turn off the computer. Unplug the notebook from the power supply and remove the battery. Wait 10+ seconds (or a few minutes) then reconnect the battery and then the power brick. Try restarting the computer. (This is a hard reset.)
What do you see on the computer screen? If you see a blinking cursor, the computer doesn't have the boot manager available (either corrupted or a new disc that hasn't had the OS installed). Use a Windows install/upgrade disc/system repair disc for your OS version (the service pack must match) or a third-party disc management tool to attempt to repair the boot manager.
You will need the optical drive as the first boot device in the BIOS or press Esc to access boot order list. (On some computers, it's F12.) For Vista or Win7, boot from the CD and follow the on-screen directions until you see a list of choices. If the hard drive was previously working, click on Repair your computer. Select the OS to repair then click Next. Select the Command Prompt option. Type in bootrec /ScanOs to get a list of available Windows OS versions on the hard drive. Use the command bootrec /FixBoot to fix the master boot record. The command bootrec /RebuildBcd will rebuild the list of Windows OS versions. See http://support.microsoft.com/kb/927392 for details.
Installing a new hard drive and reinstalling the OS may be needed if you have a SMART or AHCI/SATA hard drive error. If you have a back up image, you may be able to restore that image.
I hope this helps. Please add a comment with any error messages for more assistance.
SOURCE: Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
SOURCE: How I can remove password from bios
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: My Inspiron 1545's Webcam doesnt work at all
ok so this also happened to me but after RESTARTING my computer and then letting it fully reboot it seemed to work maybe try restarting it first and then maybe use the dell 1545 inspiron help on their website if it doesn't workk
SOURCE: my friend gave me his
Just go to here
Enter your model and hash code and they email back your bios master password for your Laptop/computer.
