My sony KDL "46vl160" sound is out of sync
1. Check your TV's audio settings:
If you're experiencing audio issues with your Sony TV, the first thing you should do is check the audio settings. Make sure that the TV is set to output audio to the correct source.
For example, if you're using an HDMI cable to connect to a sound bar, make sure that the TV is set to output audio to the sound bar. If you're using a receiver, make sure that the TV is set to output audio to the receiver.
2. Try a different HDMI cable:
If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different HDMI cable. Sometimes, the cable can be the issue.
3. Check your sound bar's audio settings:
If you're using a sound bar, make sure that the sound bar is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, make sure that the sound bar is set to the HDMI input.
4. Check your receiver's audio settings:
If you're using a receiver, make sure that the receiver is set to the correct audio input. For example, if you're using an HDMI cable to connect the TV to the receiver, make sure that the receiver is set to the HDMI input.
5. Try a different audio input:
If you're using an HDMI cable to connect your TV to a sound bar or receiver, try using a different audio input. For example, if you're using an HDMI cable to connect the TV to the sound bar, try connecting the TV to the receiver using an optical cable. 6. Restart your TV: If you're still experiencing audio issues, try restarting your TV. Sometimes, this can fix the issue.
Thanks for the feedback. I had fabricated an RCA cable which apparently was defective. I bought a premade one from Best Buy and it works like a champ.
