You need to connect either the "Audio Out" or "Monitor Out" on the back of the TV to the AV receivers "Audio Input" Most newer TV's have a digital output, usually optical, as well as an analog (rca) output. Some TV's may need to be activated thru the settings menu (audio) which will turn off the TV speakers and activate the audio output. The other way to connect is to run optical or coaxial audio from a Cable/FIOS/DSS receiver's output to the AV receiver's input. If you need further help, post a comment and I will help you further. Hope this helps
Run optical cable from your tv to receiver to get 5.1 sound.
