20 Most Recent Marantz SR-92 Mark II Receiver Questions & Answers
Is it on all audio sources or only certain ones? Have you swapped the speakers Left-to-Right to isolate the speaker from the signal chain as a cause?
If it's only an analog source doing it I would suspect a bad audio cable or a switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Marantz SR-92... | Answered on Mar 15, 2011
Is it new to you?
Make sure there are jumpers connecting the rear like in the picture.
http://www.soriaudio.com/zboard/view.php?id=m_2nd&page=3&sn1=&divpage=11&sn=off&ss=on&sc=on&select_arrange=headnum&desc=asc&no=193214
UN-select anything to do with Tape or Muting.
Marantz SR-92... | Answered on Feb 13, 2011
Hello Meredith, for what you are saying, you could have a problem in the cable that you use to send the signal you want to record, or the microphone cable or the line cable
put to record the Marantz, without any cable connected to the inputs and listen with the headphones, if the hum is, if not, try to change the cables for others of the same type, if you use microphone, controls the connectors, which do not have humidity or rust in the contacts
I hope you can solve the problem
Greetings Franco Dosil
Hola Meredith, por lo que comentas, podrias tener un problema en el cable que utilizas para enviar la se?al que quieres grabar, o el cable de micr?fono o el cable de linea
pon a grabar el Marantz, sin ning?n cable conectado en las entradas y escucha con los auriculares, si el zumbido esta, si no esta, prueba cambiar los cables por otros del mismo tipo, si usas micr?fono, controla los conectores, que no tengan humedad u oxido en los contactos
Espero que puedas resolver el problema
Saludos Franco Dosil
https://www.hifiengine.com/hfe_downloads/index.php?marantz/marantz_pmd201_221_en.pdf
Marantz Audio... | Answered 3 days ago
Hello Fernando, for what you say, your team has problems in the power output stage, the sound does not come out because there is a relay that is not activated as a result of that failure
If you have technical knowledge to review it, I send you the link so you can download the service manual, but go to a specialized technical service
Hola Fernando, por lo que cuentas, tu equipo tiene problemas en la etapa de salida de potencia, el sonido no sale porque hay un rele que no esta activado a consecuencia de esa falla
si tienes conocimientos tecnicos como para revisarlo, te envio el link para que puedas descargar el manual de servicio, sino dirigerete a u servicio tecnico especializado
http://www.go-gddq.com/upload/2014-10/14100413443414.pdf
Marantz Audio... | Answered on Apr 30, 2019
Hello Alessandro, if you have changed the three belts, it is very possible that the belt of the capstan, has been mounted on the edge of the motor pulley, which has a diameter may, therefore it will be faster the speed of the tape
Re-disassemble and observe the location of this belt, verify that it has the same thickness as the original, also observe that the capstan are with their bushings well, clean well the surfaces where the belts work with Isopropyl alcohol
If you have checked everything and do not find problems, you should adjust the speed of the motor, preferably with a 3 kHz cassette and a frequency meter or with an original, that you know the content
I sent you the link to download the service manual
Hola Alessandro, si le has cambiado las tres correas,es muy posible que la correa del capstan, se haya montado sobre el borde de la polea del motor, que tiene un diametro mayos, por lo tanto va a estar mas rapida la velocidad de la cinta
Vuelve a desarmar y observa la ubicacion de esta correa, verifica que tenga el mismo espesor que la original, tambien observa que los capstan esten con sus bujes bien, limpia bien las superficies donde trabajan las correas con alcohol Isopropilico
Si has revisado todo y no encuentras problemas, deberas ajustar la velocidad del motor, preferentemente con un cassette de 3 khz y un frecuencimetro o con un original, que conozcas el contenido
Te envio el link para que descargues el manual de servicio
espero que puedas resolver el problema
https://data2.manualslib.com/pdf5/111/11042/1104156-marantz/cp430.pdf?97bb3b8270b593cd10eab88f1605db6e&take=binary
Hello Gerry, what type of HDMI cable do you use for the interconnection, a 1.4 or a 2.0?
With the 2.0 you ensure that both devices are within the communication range and therefore should be recognized
Tell me the type of cable you use
I wait your answer
I sent you the link so you can download the user manual
Hola Gerry, que tipo de cable HDMI utilizas para la interconexion, un 1.4 o un 2.0?
Con el 2.0 te aseguras de que ambos aparatos esten dentro del rango de comunicacion y por lo tanto deberian reconocerse
Comentame el tipo de cable que utilizas
Espero tu respuesta
Te envio el link para que puedas descargar el manual de usuario
http://manuals.marantz.com/NR1605/NA/ES/download.php?filename=/NR1605/NA/ES/pdf/NR1605_NA_ES.pdf
Hello John, yes, having 5 volts DC in the output of your Marantz, will make the speakers move a lot
The weird thing is that you have that tension in the audio output of the CD17
If you have technical knowledge, you should check the audio output, mainly Mute transistors or DC decoupling capacitors
I am sending you the link so you can download the service manual
Hola John, si, tener 5 volts DC en la salida de tu Marantz, har? mover mucho los parlantes
Lo raro es que tengas esa tensi?n en la salida de audio del CD17
Si tienes conocimientos t?cnicos, tendr?as que revisar la salida de audio, principalmente los transistores de Mute o los capacitores de desacople de DC
Te estoy enviando el link para que puedas descargar el manual de servicio
Espero puedas resolver el problema
http://www.hifisounds.co.uk/manuals/Marantz-CD17MK3%20cd.pdf
Marantz Audio... | Answered on Apr 29, 2019
Hello Nate, if you can connect an amplifier to the front channels of your Marantz, to reinforce the sound
For that you have to take the audio signal from the PreOut RCA connections on the back of the SR8002, L output and R output and these 2 signals are sent to the input of your booster amplifier
I send you the link of the user manual and on page 10 you can see the back panel of your Marantz and identified with the number 12, the "PreOut" exits area, there are located the exits that I mentioned
I hope you can listen with more presence to the front channels of your audio system
Hola Nate, si puedes conectar un amplificador a los canales frontales de tu Marantz, para reforzar el sonido
Para eso tienes que tomar la se?al de audio de las conexiones RCA de PreOut en la parte posterior del SR8002, salida L y salida R y estas 2 se?ales las env?as a la entrada de tu amplificador de refuerzo
Te env?o el link del manual de usuario y en la pagina 10 podr?s observar el panel posterior de tu Marantz e identificado con el numero 12, el area de salidas "PreOut", ah? est?n ubicadas las salidas que te he mencionado
Espero que puedas escuchar con mas presencia los canales frontales de tu sistema de audio
https://www.manualslib.com/products/Marantz-Sr8002-15515.html
Hello Tvin, I have read what you have put, depending on that look for the service manual and I told you that it is very possible that the amplifier stage works well, you can check it, if you have a CD player or another sound source, if you listen, definitely the amplifier stage, it works
Regarding what you observe that when you look for the stations, your Marantz tunes them, which does not indicate that the sound comes out, I tell you why, there are several stages within the radio,
The stage of tuning and location of the stations, is the one that indicates that it found the station and it indicates it in the display, next there is the stage decoder stereo and audio output, this stage is the one that is in conflict
If you have technical knowledge, I will send you the link of the service manual, but look for a specialized technical service
I hope you can listen soon, the radio stations in your Marantz
Hola Tvin, he le?do lo que has puesto, en funci?n de eso busque el manual de servicio y te comento que es muy posible que la etapa amplificadora funcione bien, puedes comprobarlo, si tienes un reproductor de CD u otra Fuente de sonido, si lo escuchas, definitivamente la etapa del amplificador, funciona
Respecto a lo que observas que cuando buscas las estaciones, tu Marantz las sintoniza, lo que no indica que el sonido salga, te cuento el porque, existen varias etapas dentro de la radio,
La etapa de sintonia y ubicaci?n de las estaciones, es la que indica que encontr? la estaci?n y lo indica en el display, a continuaci?n esta la etapa decodificadora est?reo y salida de audio, esta etapa es la que esta en conflicto
Si tienes conocimientos t?cnicos, te env?o el link del manual de servicio, sino busca un servicio t?cnico especializado
Espero puedas escuchar pronto, las estaciones de radio en tu Marantz
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Marantz-SR-60-L-Service-Manual.pdf
I have a digital copy if you're interested
Thanks
Marantz Audio... | Answered on Mar 26, 2019
Repair the power supply problem causing on-off operation.
Marantz Audio... | Answered on Mar 11, 2019
6 questions posted
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
sr92
  • Audio Players & Recorders
