Dell GX270 P4 256/40/48X/XPP/NONE (143657523) PC Desktop Logo
A
Anonymous Posted on Nov 04, 2013
ZEBRAS ZEBRAS ZEBRAS
Please help me i need facts about zebras NOW! Please!!!!!!!!!!
How much do zebras weigh
"The common plains zebra is about 50-52 inches (12.2-13 hands, 1.3 m) at the shoulder with a body ranging from 6-8.5 feet (2-2.6 m) long with an 18-inch (0.5 m) tail. It can weigh up to 770 pounds (350 kg), males being slightly bigger than females. Gr?vy's Zebra is considerably larger, while the mountain zebra is somewhat smaller."
Wikipedia: http://en.wikipedia.org/wiki/Zebra
Where do zebras live
Though they all live in Africa, each species of zebra has its own home area. Plains zebras live in the treeless grasslands and woodlands of eastern and southern Africa. The Grevy's zebra lives in in the arid grasslands of Ethiopia and northern Kenya. The mountain zebra is found in South Africa, Namibia and Angola.
Getting blank page feeding while printing with Zebra ql420plus....but it is working with MZ320
I have experienced similar issues between two zebras. I found that the driver was the issue. I recommend:
  1. Confirm the operating system your using. [32 or 64 bit is important]
  2. remove old driver and install new driver from Zebra's support website. https://www.zebra.com/us/en/support-downloads.html
  3. If you are still having issues after all that, I really must recommend contacting Zebra as your printer may be defective and may be under warranty for service or replacement.
Alphabetical order format in MSWord
just highlight the list using your mouse or similar mechanismas if you were going to copy-and-paste them,Then select "Table" from the Word toolbar,
then select "Sort",then click "OK" your menus might have slightly different spellings)
Given the following example:
bread
apples
Zebras
Flora
Fauna
Gorillas
lemurs
Camels
They were sorted to the following using the above method:
apples
bread
Camels
Fauna
Flora
Gorillas
lemurs
Zebras
This also works if the lists has "Bullets and Numbering";
the resulting list will maintain the bullet/number order
(i.e., the numbers won't change;
e.g., in the above example,
if the unsorted "bread" was "1. bread",
then the sorted "bread" would become "2. bread",
and "apples" would become "1. apples", etc).
If you don't like the result,
then hit the "Ctrl" and "z" keys at the same time
to undo the sort.
The above method will NOT work if the to-be-sorted words
are on the same line, as with a comma-separated list
(e.g., bread, apples, Zebras, etc).
Have fun!
If you *do* have intervening stuff, such as images, etc,
then they will be sorted along with the desired words,
but the results may not be what you expect,
and you may have to do a LOT of editing to put things
the way you want, so make sure that the to-be-sorted words are on their own lines with no intervening stuff
What tricks can they do
be more especific, what you need to the printer do? what software you using?
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
