Try to disconnect power to the unit for a few minutes the plug it back in. this may clear any errors with the control board and allow the door lock to reset as well. If this does not do the trick then i would have to check the door lock motor, the switches for the doorlock mechanism and also check to see if the control board is sending power down to the door lock motor.
Does the oven light switch work? hold the button in and see if the door lock moves.
Did this occur after you ran a self-clean cycle?
