SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
SOURCE: I can't seem to set the time on my used tag heuer watch
Probably your watch has a screwdown crown and prior to attempt any
settings you have to unscrew it. Some peoples fingers are stronger then
others, so, try that with a pair of plyers. Cover your crown with a
soft cloth and then grip with plyers(this will avoid any damage).
Thread is right handed and unscrewing is done by turning the crown
anticlockwise.
After setting the time don't forget to screw the crown back- it is for water resistance.
If you are unable to unscrew the crown, that means your watch is rusty and you will need watchmakers help.
PS
If the watch is rusty, you can brake the crown off while trying to
unscrew it. Don't panic yet, as in this case you will need a watchmaker
anyway.
Don't forget to rate, please.
SOURCE: Tag Heuer Kirium Formula CL111C Owners Manual?
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.tagheuer.com/_documents/manuals/EI2245_en.pdf
