There is no sound touching icons. Never has been. There is only sound sliding the lock unless someone turns it off. As for the lock not working. Chances are your screen is malfuncitoning
The switch has a protected memory and will go to the default setting in case of power failure or shut off. Make sure you swapped it with the same watt/type bulb. You can always shut off the power to the dimmer for a few min. and turn it back on to force a reset.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Clean the
screen, if that doesn’t work. Reset the phone or use iTunes to restore the
phone to the factory defaults. If that doesn’t work you will need to take the
phone by the Apple store and have them check it out. The touch screen component
of the iPhone is like a second screen under the display; it can break and you
can still have a perfectly clear picture but no touch response.
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal 2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m). 3. Push and hold (at least five seconds) the center crown 4. Watch will beep and word (SYNCHRO) will appear in the display. 5. Use the top + button to line up the minute hand right on the 12. 6. Use the bottom – button to line up the hour hand right on the 12. 7. When finished, press crown and you will go back to time.
