20 Most Recent Honeywell RTH8580WF WiFi Thermostat Questions & Answers
The thermostat probably was reinstalled incorrectly.
Honeywell... | Answered on Oct 14, 2016
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
Honeywell... | Answered on Oct 13, 2015
It's doing whats it is supposed to do and that's regulating the ambient temperature to your set temp.
Honeywell... | Answered on Sep 27, 2015
Is there also an on/off switch for the fan on the furnace itself? If so check it make sure its set to on. Also check the on/off contacts of the switch on the t/stat to make sure its working.
Honeywell... | Answered on Feb 18, 2015
Press the FAN & the up arrow @ the same time to get into installation programming. Follow the set up numbers correlating to options in the install instructions...Make sure it is programmed for heat pump & if you have Auxillary heat. Hit Next until you get to the reversing valve position O or B ( reversing valve energized in a call for heat or cool) and switch it to the opposite of what is in the current program. Hit Done & you should be good. Hope that helps.
Honeywell... | Answered on Dec 12, 2013
The WiFi has to be on. to get to the main programming, press fan & the up arrow @ the same time for about 5 seconds. Now that you are in the programming mode, you need to scroll through to, I believe level 39 and turn it ON. This will enable the WiFi. Then press done to get out of programming mode. Your thermostat should start searching now as long as there is WiFi to connect to. Then you need to register the stat. Hope that helps.
Honeywell... | Answered on Dec 10, 2013
Unfortunately, I know what your talking about...have several in remote Drs. offices, (one in my home), & they all click when calling for heat, cool, or fan. Other than that, it is a great thermostat with easy to use free apps.
Replace unit.
Honeywell... | Answered on Oct 20, 2013
Remove power from the unit and reconnect. This will reset the unit.
Honeywell... | Answered on Oct 15, 2013
Check your red and white wire connection they are crossed or shorted some were.
Honeywell RTH8580WF WiFi Thermostat Logo
21 questions posted
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Honeywell Heating & Cooling
Most Popular Question
hoe fix honeywell rth 9580wf1013 wifi
  • Heating & Cooling
