My record player spins wayyyyy too fast, maybe 2x as fast as it should. Any way to slow it down? The adjustments on the bottom don't do anything at all.
    Guru:
  • 417 Answers
WHICH MAKE & MODEL?
YOU SAY adjustments on the bottom, WOULD IT BE A GEMINI BY ANY CHANCE?
Posted on Nov 03, 2013
5 Suggested Answers
mydogisk
  • 50 Answers
SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Posted on Apr 10, 2009
SOURCE: JVC L T11 turntable spins to fast jerry, rigged adapter
where can I get an 11V -13V DC adaptor to power JVC turntable AL-E300?
Posted on Sep 23, 2009
  • 84 Answers
SOURCE: My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
  • 14 Answers
SOURCE: Spins too fast
Check that the belt [under turntable] is`nt twisted or the 33/45 speed button is`nt sticking on 45rpm
Posted on Feb 26, 2010
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
Ipod playing too fast
In the play area of the podcast, at the top right just below where the time remaining shows there is a number plus a cross i.e. 1x, 2x etc. press the 2x and it will go to 1/2x and then to 1x. That will set it back to normal speed. Hope this helps.
Feb 13, 2012 | Apple iPod touch Second Gen (8 GB,...
My Teac sl-a100 record player sounds like a chipmunk
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Apr 30, 2011 | Teac SL-A100 Turntable
My washing machine don t do the fast spin the
it may need a new beelt on the drum as it might have buckled
Apr 25, 2010 | Hotpoint Aquarius WD63 Front Load...
My record player skips and i don't think it has anything to do with the records themselves. i try adjusting the tone arm but it does not help. also i have been noticing that it slows down and the speeds up...
What make/model?
Under what conditions does it skip?
You adjusted the tonearm (tracking force?) using what procedure and what measurement?
Is it on a solid surface away from sources of vibration (including speakers)?
Dec 06, 2009 | Audio Players & Recorders
Recording is to fast .
If it is a re recordable cassette, you can record again. But if not you cannot actualyy do anything about it.
Regards
Kanu....
Sep 09, 2009 | Video Cameras
Cd wheel spining non stop
ITS NOT THE WHEEL SPINNING ITS THE LASER ITS TRYING TO READ THE DISC THAT CAUSE IT TO SPIN FAST AND SLOW FAST AND SLOW YOUR LASER NEEDS A CLEAN
Jun 27, 2008 | Wurlitzer Jukebox 1015 One More Time...
107 people viewed this question
 Grubhead
Grubhead
