Dodge ram 1500 5.7 4x4 Cruise control shut off wouldn't come back on. Wouldn't shift into overdrive. Check engine light came on. TIA
SOURCE: o3 dodge 2500d not shfting to overdrive
had the same problem except cruse control wouldn't work either. after checking all the relays and fuses the problem turned out to be moisture in the ECM plugs.
SOURCE: Check Engine Light, plus Cruise control indicator Light both on!!
cruise light automatically comes on when there is a malfunction that causes c.e.l to illuminate,this occurs because your accelerator is electronically controled
SOURCE: cruise control light will not come on after truck
After the light goes out does it come back on while driving down the road?
If it does this sounds as if you may have a heat sensitive problem at the cruise motor. this has a sensoe that turns the light on when it is engaged. when you turn it off and sits a while does the heat under the hood goes higher expanding the circuts an open circut. You may have to replace the board in the motor.
SOURCE: 1998 dodge ram 1500 Cruise control , speed
Look under the hood to check and make sure there is two steel wire cables connected to the throttle body. i had the same problem on my 02 dodge ram, turns out that just one of the cables came loose
SOURCE: not shifting into overdrive and check engine light
I'm not a lexus guy , but I'm thinking that you have a vacuum leak somewhere.
