Car wont start, lights will come on and radio and windows. doesn't appear to be battery, but it also wont jump off either. is this the starter. makes no noise what so ever when you turnt he key
This exact same thing happened to me, it can be a number of problems. You might not have enough battery charge to get the car going since the fuel pump in this car is electronic, my car did not start but when i took it to a mechanic thinking the battery was perfect because lights and all were on they jump started it and it started then immediately died, i also had a choke pull off failure, leaks in my carburetor, and the float was to heavy causing flooding. 185 dollars later and a rebuilt carburetor my car had a smooth idle and turned on immediately after turning ignition. but then to find out my alternator was bad hence the battery only having enough power for the radio and lights.so in short try jumping the car even though the battery seems good, check your carb or get it checked by a mechanic, then check if your alternator is ok. if i waited for two days without attempting to start car then trying it would start if i held the ignition and pushed the gas pedal down until it started. (see if thats the case for you) my guess is you carb, battery, and alternator.
It is definately the starter. The starter has gone bad.
Go get a replacement.
Good luck.
Please rate this
Please see my tip at http://www.fixya.com/cars/r5821173-doesnt_car_start_gasoline_engines and let me know if you have questions.
I have the same exact problem. And i have no idea what to do, but my positive & negative cables are clean.
first inspect and clean the positive and negative cables on both ends. let me know when you do this
