Apple iPhone 5 Logo
tracy saadeh Posted on Sep 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove/uninstall cydia 1.1.8 from iphone 5
Arjun Komath
Level 3:
  • Master 1,170 Answers
  • Posted on Oct 04, 2013
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439719
Points
3355
If you ever decide that you want to undo your jailbreak, connect your device to your computer, sync to make a full backup, press Restore in iTunes to wipe the device, and load your backup when prompted. All your App Store apps and the information in them will be preserved as usual.
2 Related Answers
Anonymous
  • 31 Answers
  • Posted on Jul 19, 2009
SOURCE: I bought a used Iphone with Cydia instalIed on it.
pls change the simcard and check it
Anonymous
  • Posted on May 18, 2010
SOURCE: how to install cydia without jailbreak iphone
how can i downloads cydia for the iphone
Some appes on my iphone donat want to work
Step 1: Uninstall Cydia Substrate and Substrate Safe Mode
This should completely remove Cydia Substrate and any of its dependancies. This means that many of the tweak and apps, if not all of them, will be removed from your device. This is okay, we'll reinstall them later.
Step 2: Reinstall Cydia Substrate
This will automatically pull in Substrate Safe Mode along with it.
Step 3: Install a known working tweak
I recommend using Barrel, because I can vouch for it working on 64-bit devices.
Here's our video showing Cydia Substrate working with Barrel:
Mobile Substrate Cydia Substrate updated for all devices including the... Afterwards, you can start re installing any other tweaks and apps that you rely on. Remember, though, that if they haven't been updated to support the hardware in Apple's newest devices, then they may not work.
Let me know if this was able to help you at all in the comment section below. Now, it's time to break out that toothbrush.
tip
How to Add a Theme / Change Icons on your iPhone / iPad in iOS 7
I. Jailbreak your iPhone/iPad
To do this procedure you must be jailbroken. If you aren't, you can head to our Jailbreak How To's section and pick the jailbreak for your version of iOS (currently at the time of writing this is 7.0.4). Once done with that procedure and you have Cydia installed, head back here to continue.
*Don't be scared, it's easy to unjailbreak your device.
II. Install Winterboard
1. Open Cydia (if it isn't still open from the section above).
2. Tap Search in the bottom right corner.
3. Type in Winterboard.
4. Tap on Winterboard when it shows up.
5. Tap Install in the top right corner.
6. Tap Restart.
III. Use Winterboard
1. Open Cydia.
2. Search Cydia (either by searching using the search tab on the bottom right, or by tapping the section tab and then Themes (Springboard/Winterboard) icon).
3. Once you find the Theme you want and it says it's compatible with iOS 7, tap Install.
4. Tap Return to Cydia.
5. Open Winterboard.
6. Tap on Themes.
7. Select the theme you want to use.
8. Tap the home button and wait for it to respring the device
9. Repeat steps 1-8 to apply a different theme.
IV. Revert to the Original Apple Theme
1. Open Cydia.
2. Tap on Manage.
3. Tap on Packages.
4. Tap on Winterboard.
5. Tap Modify.
6. Tap Remove.
7. Tap Restart.
on Nov 21, 2014 • Cell Phones
tip
How to Jailbreak your Iphone 4 with firmware 4.2
1. Plug your Iphone into your computer (mac or PC) and than quit itunes/iphoto/whatever else opens up<br /><br />2. download greenpoison for mac or PC<br />(http://greenpois0n.com/)<br /><br />3. Open the .exe or dmg and run the program<br /><br />4. click start, than it is important to follow the instructions exactly as soon as each instruction is highlighting follow that instruction for as long as it is highlighted<br /><br />5. your iphone will look a little crazy DONT reboot it or touch anything it will reboot itself<br /><br />6. there will now be a "loader" application installed on your Iphone<br /><br />(I reccomend connecting to wifi for this next step but its not mandatory)<br /><br />7. open the loader app and click install cydia and then wait for it to install<br /><br />8. now cydia is installed you can use this to install a wide variety of third party apps<br /><br />Congratulations your Iphone is now jailbroken!
32helpful
9answers
Cydia free download
can i download cydia to tap iphone?
Dec 14, 2013 • iPhone Apps
How to uninstall/remove cydia
To unjailbreak your phone, you will need to restore with iTunes, however, if you would like to just remove the Cydia Installer, which is highly NOT recommended, you can do so from Cydia itself.
Just remember, uninstalling just Cydia will leave you without a Package Installer if you don't already have another Package Installer ready.
Regards,
Tristan
tip
How to jailbreak iphone 3g 3.1.2 firmware with blackRa1n
Step 1: Update iTunes to the latest version available and reboot your computer.
Step 2: Download BlackRa1n from our iPhone downloads page and install it, then reboot your PC (note that rebooting is not necessary but I always do this as a precaution).
Step 3: Plug your iPhone to your computer and launch BlackRa1n. Click on “make it ra1n”.
make-it-ra1n.png Step 4: Your iPhone will now enter recovery mode. The regular recovery mode image on your iPhone will be replaced by a picture of GeoHot.
entering-recovery.png Step 5: BlackRa1n will run on your iPhone and then it will reboot.
done.png A pop up will show up asking you to donate. If you successfully jailbreak your iPhone, I suggest you send $5 or $10 to GeoHot.
Step 6: Once your iPhone reboots, you will notice a new icon on your springboard. This is BlackRa1n. Now make sure you have internet connection and launch BlackRa1n on your iPhone.
blackra1n-installed.jpg Step 7: Choose what installer applications you want to install on your iPhone and then tap “Install”. I suggest only installing Cydia but you may install them all if you want to.
blackra1n-app.png BlackRa1n will download and install the selected applications.
Step 8: Once done installing, your iPhone will respring and you should see your installer app on your springboard.
blackra1n-cydia-installed.jpg Step 9: Once your installer app (Cydia in our case) is installed. You can safely uninstall BlackRa1n by launching the app and selecting “uninstall balckra1n”.
uninstall-blackra1n.jpg Step 10: Reboot your iPhone. You’re done!
on Apr 07, 2010 • Cell Phones
I bought a 3g 8gb iphone from a friend who bought it in australia...im in the philippines now. i went to itunes to update the iphone to 3.1.3 version, now the phone is locked! pls help me unlock it again.
it is possible but a mess about....
1. use redsn0w to install a basic jailbreak 2. when cydia has been applied with the jailbreak access it 3. search and install "fuzzyband" in cydia 4. run the "fuzzyband" app that should be on your springboard 5. this should have knocked your baseband down from 05.12.01 6. when done, reset your phone 7. while phone is off, insert new sim card
done
hope this helps
Hugo!
3answers
Unlock iPhone 3G Baseband 2.30.03
Jailbreaking is possible. But not software unlocking. For that you must buy something like a Turbo Sim. For jailbreaking try the program called Quickpwn
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
