Check the drain pump, lean the machine at a 45 degree angle against the wall. Your drain pump is black, has 1 ground wire, and a power quick disconnect. there is a little clip that you pull back, then rotate the pump counter clockwise until it pops out. You will have water coming out, so drain as much as possible before doing this. Shop vac comes in handy. F&P washer drain pumps have to functions, drain, and re-circulation. When it fills then stops, its trying to recirc, but can't. It may just be a penny or dime in the impeller. If you can't find debris in the pump, ohm out the two leads on the pump, should read 6.5 - 7. replace if anything different.
