Hi. I have a reebok T4.5 treadmill and it has stopped working. The monitor looks as it should but the buttons are unresponsive and shows 'U4' on the screen. Any ideas?
See the video and proceed according. Of course you must lube the rollers bearing front and back.
God bless you
Hi, thanks for the post but I don't think it's going to help me. The control panel/monitor is on but not responding, no button noise.
o.k adjust the REED swtich+clean it +tight the connector very weel, Test for open or faulty. Tight and clena the ribbon cable inside from display, tight and clean it the upper and low connector. However you must LUBE the deck belt very well. God bless you
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: Reebok REM 11300 have moved my treadmill, it has
I had the same problem, this is how you fix it.
remove the two black screws near the power switch and the plastic switch section should come away from the frame. Inside you should find a yellow wire, if you find this is disconnected from the other yellow wire, plug them back together and you should find the solves your problem.
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
