I have Reebok GT40s with touch screen, suddenly stopped working, unplugged it then turned it on screen comes on then Reebok sign as usual round circle of booting goes round and round but nothing happens.
It sounds like you're experiencing an E2 error on your Reebok GT40s treadmill. This error is indicative of a problem with the speed sensor, which may need to be replaced. Additionally, check your cables and connections to make sure they are all securely plugged in
There could be a few possible reasons why your Reebok One GT40s treadmill is stopping suddenly after only a few minutes of use. Here are a few things you can try:
Check the power cord and outlet. Make sure that the power cord is securely plugged into the treadmill and the outlet, and that the outlet is functioning properly.
Check the treadmill's safety key. The safety key is a small device that helps to prevent accidents by shutting off the treadmill if it becomes disconnected from the control panel. Make sure that the safety key is properly inserted into the treadmill and the control panel, and that it is not damaged or loose.
Check the belt and deck. If the belt is slipping or the deck is not properly lubricated, it can cause the treadmill to stop suddenly. Make sure that the belt is properly aligned and tightened, and that the deck is adequately lubricated according to the manufacturer's recommendations.
Check for any visible damage or loose parts. If you notice any visible damage to the treadmill or any parts that are loose or not functioning properly, it may be necessary to have the treadmill serviced by a professional.
I hope this information is helpful. If the problem persists after trying these steps, it is recommended to have the treadmill serviced by a professional to ensure that it is functioning safely and correctly.
Your treadmill may not be turning on due to a broken or a failed power supply or a broken power cord or a tripped circuit breaker switch a failed circuit breaker switch a bad power switch or wiring failure or a bad motor control board or failed console display screen can stop the treadmill from turning on. If the outlet is not working try to reset the house circuit breaker which is located inside of the fuse box to restore power to the outlet.
Hi, it may be stuck, try and force move the belt safely. if it moves turn it on again and try to start it, Be sure it has power and using the correct cables, make sure the security key is in it, make sure its setup properly without obstruction.
Good Luck
Mr.Mike
You need a new control board - around 65 UK pounds from Reebok (in uk) and pretty easy to fix. Remove 4 screws from plastic motor cover and remove cover. Loosen the circuit board hold-down screws (x2) then take phone/ipad photographs of board connections to aid re-assembly. Disconnect the 6 or 7 leads from their spade connectors. Fit new board, reconnect the leads in the same place using the photographs then, fit the two board retaining screws and replace the cover and 4 screws. Job done!
