20 Most Recent Reebok Rt1000 Treadmill Walking Belt Questions & Answers
You need to replace the walking belt.
Reebok Rt1000... | Answered on Jun 16, 2017
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Reebok Rt1000... | Answered on Jun 10, 2017
The treadbelt can be installed by removing the front roller, the drive belt, rear roller and screws in the siderail. You do not have to remove both sides, just lift the deck and slide new belt on. To save yourself some agravation, you may cut the old belt off.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly... 877-805-1030
Reebok Rt1000... | Answered on Jan 23, 2016
Hi Helen, ...if you find the part hard to come by, you may be able to use longer bolts that extend past the end of the plastic cap, and use oversized washers as an alternative. Ben Bass [email protected] 0403 969 946 Senior Service Technician 15 years GYMWORKS #treadmillrepair #treadmillbelt #gymworks #healthequip www.treadmillbelts.com.au
homepage
Reebok Rt1000... | Answered on Jan 07, 2015
just bought one second-hand from someone and set it up in out flat. Had a liitle play and cranked it up to 9.5mph which was too fast for me so at least that!
Reebok Rt1000... | Answered on Jul 04, 2013
adjust the REED switch see the diagram, clean it, and tight the wires connector very well.
2) tight the ribbon cables from keypads,+tight the wires connector from display board vs lower board.
God bless you
Reebok Rt1000... | Answered on Jul 23, 2012
Dear Sir:
Hello, I hope everything is fine, in union with your family.
I will try to help you, inmediately.
INSTRUCTIONS: You must be carefully to do this.
    • 1
Cleanand routinely maintain the running belt. The belt may be worn if the treadmillstops operating or trips the circuit breaker or fuse. Look for any tears in the belt.Test the belt by putting the treadmill at full incline. If it does not shutoff, you may need to replace the belt. You can try lubricating it first, butthe safest fix is simply to replace it.
    • 2
Tightenthe running belt if it is loose. A belt can slip if there is too much friction.Be careful not to tighten the belt too much, though. You should be able to liftthe belt at least 3 inches.
    • 3
Pushthe belt in the direction that it normally turns. Turn off the power before youstart. If the belt is difficult to turn, there is high belt/deck friction.However, if the belt moves freely, that's not the problem.
    • 4
Examinethe roller sleeve to see if it is centered on the running belt. If not, this couldcause the belt to move to one side. Often a common problem with treadmills, youcan try making adjustments yourself, but eventually you may need to replace thesleeve or roller.
    • 5
Stopthe treadmill and immediately unplug the power cord from the outlet if younotice a burning smell. Overheating could be a sign that there is too muchfriction or a short in the wiring. Examine the belt and deck for any signs ofwearing. If they check out alright, inspect the wiring. Replace any damagedparts as needed.
    • 6
Checkto make sure that the power switch is on if you suddenly lose power. If thisisn't the cause of the power loss, unplug the treadmill from the wall outletand individually test the fuses, breakers and switches. Test the wall outletfirst, as a fuse may have blown or a circuit breaker tripped.
    • 7
Allowthe treadmill to run at a speed of 2.5 mph without anyone walking on it if younotice fluctuations in the speed. The speed should be constant. If not, therecould be a problem with the motor.
    • 8
Testthe motor using a fully charged lantern battery. The motor should still operateat slow speed.
    • 9
Replacethe batteries in the panel if it dims. If the batteries aren't the problem,check to see that all the wiring is still intact. Sometimes a wire pulls loose.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please reach me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Reebok Rt1000... | Answered on Oct 03, 2011
in the manual there is a exploded view and all parts are numbered go to web site or call and order the part.
Reebok Rt1000... | Answered on Mar 08, 2011
Reebok Rt1000 Treadmill Walking Belt Logo
46 questions posted
Top Reebok Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Christopher DeSantis
Level 1 Expert
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Reebok Exercise & Fitness
Most Popular Question
reebok rt1000 treadmill instruction
  • Exercise & Fitness
