I have an old Comoaq Armada E500 notebook. I recently purchased a EIDE 80GB hard drive. I then purchased a USB to IDE/SATA converter. My computer only has one USB port which does not work, so I have a USB card adapter with two ports. All USB devices work with this item except this hard drive.
The hard drive shows up in the device manager under disk drives as a USB device but with no space info attached to it and it shows up no where else on the computer.
I have tried disk management but there is no pop up and it does not show up there only the CD drive and the main hard drive.
I need this thing to work...I do not have enough space on this lap top to run the programs I need to use and I cant buy a new PC right now. This is supposed to be easy...HELP!!
I do not believe it is, when I purchased it the said they would format it for me...Im not sure what they did????I do not believe it is, when I purchased it the said they would format it for me...Im not sure what they did????
Do you have a desktop computer to format the drive in? or a 2.5 ide to 3.5 ide converter?Do you have a desktop computer to format the drive in? or a 2.5 ide to 3.5 ide converter?
Ok, the hard drive needs to be formatted before it will show up under disk management. Is the drive a 2.5( meaning that it will fit in your laptop) or is it a 3.5(designed for a desktop or external use)? If it is a 2.5 i'll walk you through how to format it with your laptop. If it is a 3.5 you will need a desktop computer a converter.Ok, the hard drive needs to be formatted before it will show up under disk management. Is the drive a 2.5( meaning that it will fit in your laptop) or is it a 3.5(designed for a desktop or external use)?
Does it have a 4 pin power connector on the back next to a place to set the master and slave jumpers, next to the ide connector?Does it have a 4 pin power connector on the back next to a place to set the master and slave jumpers, next to the ide connector?
Ok, it sounds like you have a 3.5. If you have a friend or relative close by that has a desktop computer I can walk you through partitioning and formating the hard drive. Just let me know when you will be there and we can plan for it.Ok, it sounds like you have a 3.5. If you have a friend or relative close by that has a desktop computer I can walk you through partitioning and formating the hard drive. Just let me know when you will be there and we can plan for it.
You can't post conmments that contain an email address.
AU $8.09
free postage worldwide
You would have to remove the hard drive and use a usb
sata ide kit
you will then have to
connect it to your computer using a usb port
AU $8.10
sata ide kit
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
You got the "improper removal" message WITHOUT having actually removed anything?
This is, quite often, the mark of a dead drive. If you're lucky, the host controller electronics died, and you'll be able to recover all of your data by purchasing almost any kind of EIDE 2.5" USB enclosure - a few dollars on eBay - and shifting the internal hard disk from the Passport enclosure to the new one.
If you're not lucky (and unfortunately, the 80GB drive isn't very recent and old drives tend to die on you), the electronics is working, but the internal hard disk is dead. You may be able to have it serviced by a data recovery firm, but it could be quite costly.
It is quite easy, do not worry. You only need to bought and USB enclosure, here is a link to many products on ebay http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it. Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive. Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay. The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
The 80GB would be better, these days games take alot of room and 20GB would fill up very fast and they would start asking why cant I install my game? becouse the disk is full after few months.
80GB will go along way as long as the useless files are removed.
Right click on My computer,then manage,disk management, if popup occur,click yes to all and finish,then right click on new drive,create new partition,click yes to all, wait for format.....done.If you don't want to format or already formatted then right click on drive, change drive letter and paths and assign new drive letter away from c.d or e...make it x...problem should be solved
JJ
No, only another lap top and its a G3 mac
No only a G3 laptop mac
I think its a 3.5.
there are ten
