20 Most Recent
Seagate Barracuda 7200.10 320 GB SATA Hard Drive Questions & Answers
Drives Not shown
Download testdisk and run it to see if it recognised in the list. If so use the intel option to find a boot sector
10/11/2017 9:36:52 AM •
Seagate...
Answered
on Oct 11, 2017
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
12/10/2015 1:31:03 AM •
Seagate...
Answered
on Dec 10, 2015
Bootmgr is mising/cant install win 7 on seagate HDD configuration problem
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cablesAnothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
5/5/2012 9:13:55 PM •
Seagate...
Answered
on May 05, 2012
My seagate 320 GB
my hard disk was 320GB bu that displayed only 298gb shall i no that reason
1/29/2011 12:16:27 AM •
Seagate...
Answered
on Jan 29, 2011
Describe your Seagate Barracuda 7200.12
It requires special hard ware tools to solve this problem. they are available with me and it just takes 20 minutes to get your data back. this is called LBA ZERO REPAIR, AND TRANSLATOR REGENERATION.
12/19/2010 4:55:41 AM •
Seagate...
Answered
on Dec 19, 2010
Has died. Making this horrid
With luck your PC could still be in warranty, if so go back to the vendor.
If not, its a case of buying and installing a new HDD. You'll also need to re-install an operating system.
If you don't have one on disk, try downloading and installing Ubuntu, its free also got free office software and loads of other applications.
9/23/2010 6:43:56 PM •
Seagate...
Answered
on Sep 23, 2010
Drive does not show up
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
9/19/2010 10:10:53 PM •
Seagate...
Answered
on Sep 19, 2010
When I boot my pc
You will have to get a bootalbe disk of Windows to repair the Windows installation.
8/8/2010 1:54:47 PM •
Seagate...
Answered
on Aug 08, 2010
I want seagate service center address in kolhapur,
Call on the Toll-free Phone: 000 800 440 1392 they should be able to help. But as far as I know there isn't any service centre of Seagate in Kohlapur.
Nearst service centre is in Mumbai
F-7,B-5,Rainbow Building,Sec-10,Vashi
Navi Mumbai, Maharashtra 400703
4/17/2010 1:44:31 PM •
Seagate...
Answered
on Apr 17, 2010
No hard disk found......
You must first press f6 to load the SATA drivers for the hard drive before you go forward with the install.
Good Luck,
NOLA Tech
2/6/2010 7:00:42 AM •
Seagate...
Answered
on Feb 06, 2010
Hi. my computer crashed a
Well the drives are set to raid 0, if you're seeing 640GB. This implies that data will be stored on the first one till it's full and then move on to the next. If you have less than 320GB of data and you've lost drive 'A', then the chances of retrieving the data are slim. Your only options are then to try some recovery software or head off to a recovery company. Try running a diagnostic software on the drives individually to determine which drive is faulty.
1/20/2010 7:08:12 PM •
Seagate...
Answered
on Jan 20, 2010
My Seagate Barracuda 7200.10 320 GB SATA Hard
Hard drives are only designed to last 3 to 5 years. Most hard drive manufacturers only warranty them for 1 year.
For whatever reason yours has died.
Backing up your data is imperative.
If you need to recover data from this hard drive, there are places online that you can send the drive to and they can recover the data on your hard drive. This can cost you a bundle though. If the data is not necessary, all you can do is buy a new one and reinstall your operating system.
11/28/2009 11:01:12 PM •
Seagate...
Answered
on Nov 28, 2009
Seagate Barracuda 7200.12 show 0MB issue
I would first look for a bios update for your motherboard to see if that helps at all.
If your bios did not fully support 1TB and special installation software was used to make it work by a method that uses overlay that would cause it to run slowly
To make it run faster I would have set up a primary partion of around 100GB and installed to that and left the rest of the drive formatted for general storage.
You may still want to look at that as an option.
If not and you did use any overlay software you are going to be restricted to slow speeds try putting it in another computer and transfer anything you want from it that way. when you are done you can actually delete the partitions etc using the other computer to do so.
You could also set it up on there ready to try re-install windows XP
Or it could just be that you have a nasty and I would certainly try get data off and re-format whilst you are at it if you have
If this info was useful then please click
8/13/2009 5:35:15 AM •
Seagate...
Answered
on Aug 13, 2009
Windows xp will not recognize my seagate barracuda
If you have one HDD set it to master with your jumper settings. Try again. If No go than change the cable connector. If SATA HDD than change the connector on the MOBO try another connector. Restart. If still no go than write back
7/30/2009 2:21:19 AM •
Seagate...
Answered
on Jul 30, 2009
