Hi somisettiky, the laptop has a crystal eye icon on the desktop by default so you can take picture using it. if you have yahoo messenger, you can use that to as a webcam, same with skype or other video conferencing softwares.
guest, the crystal eye does not have a time delay shot be default, you may use a utility from acer to optimize the use of your mounted camera.
regards,
voodoo
SOURCE: no driver for built in web cam for acer aspire 5603wlmi
http://support.acer-euro.com/drivers/downloads.html THERE U FIND YOUR DIVER.
SOURCE: Web cam
Was the webcam factory installed?
If so, find "My Computer" or, I guess, "Computer " in Twista, and double-click on it. The webcam is probably listed in devices you can open at the bottom of the list... double-click on it.
Alternately...
Start...
Run...
"msconf.exe"
<enter>
But of course, blista does not put the "run" command on your start menu by default, so you will have to manipulate the properties of your task bar to show the "run" command.
SOURCE: How do I use my acer web cam? I can't get to it.
well mine is called crystal eye web cam just go to your search on the computer and type in web cam and it should pop up
SOURCE: I can't get my Acer Aspire web cam to work. It's
you may have to go to the cmos and and activate it when computer is turned on hit f1 or f2 or del key to inter cmos
how can i wait 3 seconds before the crytal eye takes a picture?
