My mouse i just brought has stop moving but the curser is still on the screen and the light is still on at the bottom. it wont click
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click on >> control panel all control panel items mouse you should see
(4 tabs buttons pointers pointer options)
and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
batteries in LX5 cordless mouse are good, light on bottom is on, but the cursor won't move. had a power outage, could that have caused a problem?
