I just want to know where the pcv valve location is so I can replace it my self with out paying an arm and a leg to have someone else do it.
Please rate as fixed if this helps.
4 cylinder
SECTION 303-08: Engine Emission Control
2003 Escape Workshop Manual
REMOVAL AND INSTALLATION
Positive Crankcase Ventilation (PCV) Valve —2.0L Zetec
Removal and Installation
WHERE I CAN FOUND PCV HOSE ON MY FORD ESCAPE XLT V6 YEAR 2003
'01 Escape V-6 PCV valve is harder to do. I read other articles on how to do it, many good, some bad. I removed the "appearance cover" to see it better only. I removed the air intake hose and air filter housing to get some working room. I used a flashlight to get a better look at it. The hose attached to the PCV valve is joined together in pieces. When I pulled to remove this hose, the last little piece stayed connected to the PCV valve on the engine. I used a 9" long nose plier and turned the PCV valve and the little piece of hose counterclockwise and it came off. I cleaned the little piece of hose and attached it to the new PCV valve before reinstalling. I then inserted the new valve with piece of hose attached and turned it clockwise with the long nose pliers and made sure it was snug before I put everything back together.
The PCV valve is located 60 degrees from the driver side. Under the intake manifold coming off the center. Just about a blocks length of distances there is a Z-connector running down the side of the firewall cover. Once you locate the rear motor arm move directly down (horizontally) to the female extender. Open the cover and press lightly with strong mussels on the clamp hoses. Release the rear bumper and jiggle the left arm firmly until the latch reconnects. Disconnect the latch again. The PCV valve should be in plain sight now. It's nearly impossible to local on a rainy day and just as easy when the suns outs puns outs. The Dealership swears the Part # Z-SPARTA1 fits the 2011 models, however, check with your local emissions office to ensure road safety compatibility.
