The following connections should be made:
1) Connect a cable from your wall receptacle to the RF IN on the back of your Panasonic unit..
2) Connect a cable from the RF OUT on your Motorola Cable Box to the RF IN on the back of your TV.
3) On the back of your DMR-EH75V there is a set of connections labelled L & R AUDIO OUT as well as VIDEO OUT. Run a cable (this was supplied with your Panasonic unit) from those conections to the connections labelled AUDIO IN R & L and VIDEO IN.
4) On the back of the Panasonic unit is a connection labelled RF OUT. Connect that to the RF IN on your Motorola unit.
5) On the back of the Motorola unit are connections labelled AUDIO OUT R & L and VIDEO. Connect a cable from there to the connection on your Panasonic labelled IN3 R AUDIO L amd VIDEO.
6) Attach all power cables. You can then follow your Panasonic manual to chose the correct settings depending on what you want to do.
All of the cables that you need should have been supplied with your units. They should be labelled AUDIO L & R and VIDEO for both IN and OUT. In case you do not have your manuals handy the following links will take you to copies you can download. Your Panasonic manual can be found here:
http://safemanuals.com/314159.php?k=1f679431db21b6e4e5e158e1fd0fb110&ID=194497&q=PANASONIC%20DMREH75VThe manual for your DCT2222 is not on the web but the manual for the DCT2000 will work as the connections are the same. Use this URL:
http://broadband.motorola.com/consumers/products/DCT2000/downloads/DCT2000_User_Guide.pdfIf you still have any questions please let us know. Thank you.
