What color paint do you get for a whirlpool bisque colored rough finished refrig
SOURCE: Whirlpool side by side refridgerator doors rusting
sounds like an older refrig, we call that "refrigerator cancer", its rusting from the inside out. your inner insultion has become saturated w/ moisture and is just rusting away now, you can try covering witha rustolem might buy you some time only other way is to replace entire door and thats a few hundred dollars
SOURCE: Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
SOURCE: The paint on the front of my Whirlpool
You can purchase a bottle of rust converter at any auto parts store, and then all you need to do is purchase appliance paint..
SOURCE: Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
SOURCE: wHIRLPOOL SIDE BY SIDE fridge GD25DFXFW 10 YRS
Get your refrigerator repainted before it is too late. It isn't that costly. Cracks may be due to rusting. Ask those mechanics about it when you give it for painting.
