eMachines E19T5W 19" Monitor Logo
margie ropp Posted on Apr 08, 2009
When I turn the computer on I have to press the button on and off several times before the monitor will come on
Anonymous
Level 1:
  • Contributor 23 Answers
  • Posted on Apr 08, 2009
Anonymous
Contributor
Level 1:
Answers
23
Questions
Helped
4994
Points
53
First try using a different connector.......or a different monitor and see if u have the same problem with it...............if it gives you the same problem u can try downloading the monitor driver to a cd (when u can get it to come on).....then re install the driver............ if this doesnt work it may be a faulty monitor card in the back of your computer that needs to be replaced.
1helpful
Need OSD Lock out removed permently Please
have you tried the following steps:
  • Press and hold the "Power" key on your monitor to turn it on. Press the "Menu" button for 15 to 20 seconds to cancel the OSD lockout message.
  • Press the "Power" button on your monitor for several seconds until you see the OSD lockout message disappear. Unplug and re-plug your monitor power cable back into the outlet if the OSD lockout message is still displayed.
  • Turn your computer's monitor off. Press the "Menu" button for 15 to 20 seconds and power your monitor back on.
  • Read more : http://www.ehow.com/how_10015851_fix-osd-lockouts.html
    Black screen when turned onno display
    There are several reasons that your Toshiba laptop screen may not come on, even if the laptop appears to be running, and several options you may try to get your screen back up and running without an expensive service call.
    Common causes for a blank screen include a backlight that is turned off, a display toggled to an external monitor and improper shutdown errors.
    To avoid blank screen errors after your current error is fixed, make sure to follow all instructions in your user's guide to care for your Toshiba computer.
    Shine a flashlight directly at your screen and look for an image.
    If you see one, this means the backlight on your laptop is off but the screen is still working. This backlight normally turns off only when your screen is closed.
    Look for a small metal or plastic pin near one of the screen hinges.
    The screen pushes this pin in when it is closed, so if the pin is stuck in the screen closed position, the backlight will remain off.
    Tap the pin several times to release it.
    You may need to use a small object, such as a pencil tip or straightened paper clip, to reach it on some models.
    Monitor Toggle
    Press and hold down the "Fn" key if you do not see an image when you use the flashlight.
    Tap the "F5" key several times while the "Fn" key is pressed.
    This will cycle your screen through the various options that toggle the display to an external monitor.
    Attach an external monitor, restart the computer and try this method again if no image appears on the laptop screen.
    Click "Start," "Control panel," "Hardware and sound," then "Device manager "using the external monitor if you get an image there but cannot toggle the image back to your LCD.
    Select the "Monitor" option to expand your selection and select your LCD monitor from the device list.
    Click the "Driver" tab and select "Update" to update the driver, as this error is likely caused by a software driver error.
    Force Restart
    Press and hold the power button until the computer shuts down completely.
    Check the indicator lights at the edge of your laptop to see if the computer is truly off or if it has simply gone into hibernation mode.
    If it is off, all lights will be off except the battery-related lights if you have a charger plugged in. In hibernation mode, the power light will blink slowly.
    Press the power button to restart the computer again after leaving it off for 15 to 20 seconds. This may fix the problem.
    If the blank screen returns or you get a flash of images and then a blank screen, move on to the next step.
    Force Power Down
    Unplug your laptop from the power source.
    Remove the battery by pressing outward on the battery latch and pulling the battery unit completely out of the computer.
    Press the power button several times to completely discharge the computer.
    Replace the battery and plug the computer back in after about 30 seconds.
    Press the power button to turn on the computer.
    If you get an error screen upon startup, choose to restart Windows normally.
    This error is caused by improper shutdown procedures.
    Hope this helps
    My toshiba l355d black screen all fans and lights are working
    Monitor Toggle
    Click "Start," "Control panel," "Hardware and sound," then "Device manager" using the external monitor if you get an image there but cannot toggle the image back to your LCD.
    Force Restart
    Force Power Down
    Hope this helps
    1helpful
    Laptop is run and start but no display
    Monitor Toggle
    Force Restart
    Force Power Down
    Hope this helps
    2answers
    9helpful
    OSD locked. Can't get mouse to work on monitor
    -Press and hold the MENU button (on the monitor) for several seconds.
    -The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear
    2answers
    Problem with dell lcd monitor
    Frt. Power button control board shorted. Part# 715L1153-1A
    15helpful
    4answers
    OSD Lock
    • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
    1helpful
    Pop goes the weasel
    I agree. The monitor probably blew a capacitor.
    Time for a nice new LCD monitor.
    Top eMachines Computers & Internet Experts
    Andrew Chrostek
    Andrew Chrostek
    Level 1 Expert
    Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
