Speed display went from normal operation to zero. Did this on & of for about 4/5 hours during voyage then failed completely. Removed unit & display head to work bench & applied power. No go. After a number of false starts it appears putting the unit into extended calibration mode, step thru the various options without changing any values will most of the time get it to operate. Sometimes requires to do this 2or3 times. Next time power is applied it may or may not work. Prior to failure the anchor winch caused severe voltage drop due to batteries being in a low state of charge. Is there a master reset procceedure as I suspect the CPU has been scrambled?
Jim
We encountered the same problem as well. I was able to get the unit to read correctly using the extended calibration procedure outlined above. Since our sea temperature function crapped out a couple of years ago, I'll be installing a new transducer in 2015. I'll let you know how successful this is. Stay tuned.
(EDIT)
I replaced the transducer (http://ca.binnacle.com/Electronics-Transducers/c12_565/p7221/RAYMARINE-SPEED-TEMPERATURE-TRANSDUCER-E26031/product_info.html) and it couldn't have been easier. Had to replace the thru-hull but the cable was a simple splice color-for-color. Done.
Just for fun I took the paddle wheel from the new ducer and installed it in the old one. Worked perfectly. You MIGHT get away with simply buying the paddlewheel kit (http://ca.binnacle.com/product_info.php?products_id=7509). I'd try that first.
-Steve
Hi Jim , I have the same problem. Did you solve yours thank you Martin RestauratorHamburg a yahoo.com
Martin, after many false starts (red herrings) during bench testing I stumbled on the real fault. This was an intermittent connection inside the transducer paddlewheel module. I was clamping the module about halfway along in the vice to enable me to spin the paddlewheel when I discovered that in one position it would work, but by turning it 90deg & re clamping it would not. This was repeated many times. Replace paddlewheel sender unit --about AUD$200. Dismantled the unit to try a repair but this resulted in total destruction. Hope this helps, Jim
