The 3 things needed for an engine to run:
1. Compression (Cylinder, Piston, rings, gaskets)
2. Ignition (Spark plug, ignition module/coil)
3. Fuel (Fuel lines, Carburetor, gaskets, bad fuel)
More than Likely I would start by checking fuel related since that is usually the biggest offender (fuel lines broken/dry rotted, bad carb.)
Sounds like the motor has gone on this. Get it checked out but it might not be economical to be repaired. It could cost at least 50.00 for the parts alone.
You burned up the magnetron. It is not a hard replacement but requires a few checks first. I have a tip at http://www.fixya.com/support/r4265491-replace_bad_magnetron which explains the process in detail and lists where to buy the parts you will need. Let me know if you need more help.
