Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46 Logo
A
Anonymous Posted on Aug 12, 2013
Where is the 20 amp fuse located in YTH20K46 - Husqvarna Riding Lawn Mower 46 Cut Kohler Yth21k46
Jennifer Rock
Level 2:
Novelist:
  • Expert 153 Answers
  • Posted on Apr 29, 2018
Jennifer Rock
Expert
Level 2:
Novelist:
Answers
153
Questions
Helped
107381
Points
339
TO REPLACE FUSE Replace with 20 amp automotive-type plug-in fuse. The fuse holder is located behind the dash.
Here is the instruction manual: http://www.husqvarna.com/ddoc/HUSO/HUSO2006_USen/HUSO2006_USen_O0602057_.pdf
2005 escalade ecu fuse location
location - under hood fuse / relay box. PCM 1 fuse 15 amp , PCM B fuse 20 amp. Plus instrument panel fuse block , IGN O fuse 10 amp . Fuse Block - I/P
At the left side of the I/P behind the access panel
1helpful
Central power supply and Cargo supply fuse location for 2007 Chevrolet Captiva?
Where are you located ? USA .
Fuse # 34 20 amp instrument panel fuse box . Cigar lighter is fuse # 33 20 amp , Fuse 32 20 amp power out cargo .
2helpful
2answers
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
What is a 20 amp cb fuse
a 20 amp cb fuse is large fuse usually located in a plastic case in the engine compartment. This fuse is over 1 inch long and I believe the 20 amp is green in color and should say 20 on the top. On a Ranger it is usually located on the Driver side of the engine compartment close to the brake booster.
2helpful
Relay Box for 1994 ford mustang cobra
relays are normally in the fuse panel on the left side of dash by knee.
Fuses and Circuit Breakers Location and Values
NOTE: The headlamp switch (11654) has an integral 20-amp circuit breaker.
  • The combination instrument panel fuse and circuit breaker panel contains most of the fuses and circuit breakers used in the system.
  • The fuses and circuit breakers are color-coded by amp rating.
  • The locations and values of the fuses and circuit breakers not contained in the panels are shown in the following chart.
Circuit Circuit Protection and Rating Location Headlamps and High Beam Indicator 20 Amp. CB Integral with Lighting Switch Heated Back Window 16 GA Fuse Link Engine Compartment Power Windows, Power Seat, Power Door Locks 20 Amp. CB Starter Motor Relay Load Circuit Fuse Link In Harness Engine Compartment Lamp Fuse Link In Harness Convertible Top 25 Amp. CB Lower Instrument Panel-Reinforcement
Cavity Number Fuse Rating Color Circuit Protected A 40 Amp Orange
  • Ignition Switch
B 40 Amp Orange
  • Ignition Switch
C 40 Amp Orange
  • Ignition Switch
D 50 Amp Red
  • Headlamp Switch
  • Instrument Panel Fuses 4, 8 and 16
  • Instrument Panel Circuit Breaker 12
E 20 Amp Light Green
  • PCM
  • Fuel Pump
  • HO2S (3.8L)
  • Canister Purge Solenoid
  • EVR Solenoid
  • Ignition Control Module (3.8L)
  • IAC Solenoid
  • Fuel Injector
  • Automatic Transmission
  • Camshaft Position Sensor (3.8L)
  • MAF Sensor
F 40 Amp Orange
  • Heated Back Window
G 20 Amp Yellow
  • Fuel Pump
H 60 Amp Blue
  • Fan Control
J — — Not Used K 10 Amp Blue
  • Anti-Lock Brake Control Module
L 20 Amp Red
  • Fan Control Monitor (PCM)
M 25 Amp Yellow
  • Horn
  • Foglamps
  • Daytime Running Lights Control Module
N 25 Amp Clear
  • Fuses 5 and 9
P 20 Amp Clear
  • Radio Amplifier
Q 20 Amp Yellow
  • Generator
S 30 Amp Yellow
  • Convertible Top Motor
T 60 Amp —
  • ABS
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
