Question about KitchenAid Kitchen Ranges
Fuse chart is missing for model YKERS507AA0 Kitchenaid Range
Fuse chart is missing for model YKERS507AA0 it is not in the use and care guide stove was purchased in 98 or 99 Problem is I had one (15a) fuse out on stove top and one in my hand(30a) now I do not have the chart I can not put either in as I do not want to overload or underload the panel Have tried locating same model in used store no luck with that.This range is a KitchenAid Superba Selectra Thermal-Convection Electric range there are 8 fuses under the florescent bulb in the lift up panel at top of stove
Posted by alinasmom on
  • Ariadne7
    Ariadne7 Mar 06, 2016
    Did you get an answer to this/find a fuse chart yet for this model? I am looking for this same glass fuse plug chart as well. One element is not working, and currently the 8 plugs are showing (Left to Right): 20 Amp, 20 Amp, 30 Amp, 15 Amp, 15 Amp, 30 Amp, 20 Amp, 20 Amp -- BUT I am not sure if those middle (15/30 Amp) fuse plugs are correct....I found the corresponding manual for the YKERS507AA0 model online, but you are correct - it does not show the fuse chart for the fuse plugs located beneath the panel, under the fluorescent bulb!
Ariadne7
    New Friend:
Posted on Mar 06, 2016
Anonymous
  • 22 Answers
(www.appliancepartspros.com) Only shows a 15amp fuse under the light cover.
Posted on Mar 30, 2009
Need replacement parts
You may try to fin some websites silleing replacemete part for your unspecified kitchen range doing a google search for terms Parts, make and model of your kitchen range.
For a generic search look at
http://www.repairclinic.com/Shop-For-Parts/a13/Range-Stove-Oven-Parts
http://www.repairclinic.com/Shop-For-Parts/a13b121/Kitchenaid-Range-Stove-Oven-Parts
parts kitchen range Google Search
Find parts by model number
and much, much ore...
Aug 18, 2015 | Kitchen Ranges
Oven keypad is completely black but inside oven lights work. does keypad have a separate fuse?
Yes. Many of these have a display thermal fuse that is part of the wiring harness that connects to the board... it should have continuity. WP4451042. Almost all models have what is called the "oven shut-down thermal fuse" which is on the back of the machine ( you have to pull it out of the wall and remove the back panel) and looks like this KitchenAid Range Stove Oven Thermal Fuse WP9759242
Dec 06, 2014 | KitchenAid KEBC208 Electric Double Oven
Kitchenaid stove code f68
This stove should absolutely still be under warranty. I would start with calling the KA customer service. They are pretty good and will usually do all they can to help you. The number for them is:
800-422-1230
Jan 03, 2014 | KitchenAid Electric Stove Range...
I am trying to put fuses into a kenmore range - which goes where
Use the highest rated Fuses on the main stove heating Elements, and the lower rated ones on the Stove top Elements.
Mar 18, 2010 | Kitchen Ranges
Can't find my owners manual for my kitchenaid stove electric with bottom warming drawer - need to do a self cleaning and don't know what to do? Do I need cleaning product and how long will it take?
If the model number is correct, you can find your owner's manual (with self cleaning instructions) and installation guide listed at managemyhome.com. Just type in the model number under the "Manuals" link and your manuals are available in a .pdf (Adobe) format that you can download or print for FREE. I hope this helps you.
Nov 27, 2009 | KitchenAid KERA205P Electric Kitchen Range
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Do they still have this stove in stock
THE MODEL SERIAL PLATE IS LOCATED BEHIND THE STORAGE DRAWER/BROILER ON EITHER THE LEFT OR RIGHT LEG OF THE RANGE.
Mar 31, 2008 | KitchenAid KESC307 Electric Kitchen Range
Range element does not work
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 25, 2007 | KitchenAid KERC507 Electric Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
1,004 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
