Model YTH20K46 connected battery poles to wrong wires...will not crank now
SOURCE: Husqvarna riding mower. Wont start.
check your switch for your blades take it off(shut it off)
SOURCE: Yes I need help on
My name is Dane and I am going to help you solve your problem.
Drive belt: 532 13 09-69 Deck Belt: 532 40 51-43
Here's a link to your manuals!!!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=yth20k46&types=O,I
I hope I've helped! Thank you! Dane
SOURCE: Husqvarna 48" Lawn Tractor:
The link below for details of wiring. Assuming good connections at the battery and ground to frame. Your unit uses lots of 12v power for charging, lights and the electric clutch (must have good charging system to run this mower). There is a fuse between the amp meter and starter solenoid. If the fuse is open, the meter will not show charge or discharge. No start or even click would indicate that one of the safety cut-out switches is not engaging (seat, break/clutch etc.). Easy to test switches with meter (refer to wiring details at link below). The charging system is easy to test with meter. Once you get the engine running, test for 28volts ac (3600rpm) from two wires at the regulator (two wires from ac alterator under the flywheel of the engine). Then look for 12 to 14 volts dc at the output side of regulator. Good luck with repair
http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2011/HIUS2011_532440469.PDF.pdf
