Philips HTS3011/05 Theater System Logo
Anonymous Posted on Aug 05, 2013
Standby light flashing unit will not turn on
Have tried replugging in, remote batteries changed however no red light comes on to indicate it is working either
1 Related Answer
Anonymous
  • Posted on Dec 29, 2009
SOURCE: I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
37LC2D LG PLASMA TV Solid red light is on no sound picture
The unit is stuck in standby. Have you tried turning it on manually on the set or changing the batteries in the remote. Does the light flash when you try to turn it on?
[email protected]
Only red standby light comes on,Hit power button on remote, light goes out,unit turns off and have to replug into wall to get red light on.
There would be some problem in the output amplifier stage. Thats why its going to protection mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My remote is red light is flashing. I changed the batter and the battery in the unit is working. I can turn on the fireplace manually
  • The usual indication for a flashing light is a low battery. Suggest checking the remote again. Especially for corrosion at the battery terminals.
  • When you operate the remote will the receiver flash its LED indicator confirming that the command has been received.
  • The manual operation of the receiver located at the fireplace likely does not require batteries. For remote control operation good batteries are required.
  • If the red LED on the receiver is flashing the batteries need to be replaced.
  • If the LED at the receiver indicated that the command is received check the wires to the control valve from the receiver. The voltage is a very very low a millivolt signal.
Infrared indicator light will not come on all buttons flash multiple times
um..you wont see the infra red with the naked eye..you can only see it using nite vision style equipment..something that shows in monochrome which is that frequency..if it lights up it is supposed to be working..some need reset to the units in use when the batteries are replaced..use the search mode on it..
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
1helpful
Lamp replaced, sequence from Manual (p.49) for 2010+ hrs fails
Apparently, the above posted steps do work, but they are finicky. The manual suggests that you do the aforementioned steps with the remote - I had tried with the remote and when that did not work I tried directly on the controls on the unit itself. Neither had worked - after multiple attempts, hence the posting above. The solution was that the various steps need to be done speedily - when I previously did it I apparently did not press the sequence rapidly enough. Nothing in the manual suggests that this is the case (and in fact I thought I had previously followed the steps in rapid succession on at least one of the many times I had tried, but apparently not quickly enough). I never could get this rapid succession of steps to work with the remote (as the manual said I needed to), but I did ultimately get the rapid succession of steps to work when done directly to the unit itself. The first three steps need to be completed within approximately 1-1.5 seconds, the final push of the volume+ button did require 2 or more seconds before the process was recognized (and complete). Never did have a single FixYa party try to address my issue - perhaps you only really get responses from them when you pay for their monthly service.
1helpful
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
3answers
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
3answers
Bush digital terrestrial receiver dfta 11
Hi John
If you havent allready try unpluging the unit from the mains.
Leave out for 5 mins then plug back out & allow system to reboot.
Cant guarantee this will work but it does solve a lot of digi box problems.
http://dysonmanuals.llc.nu/
Chris.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
