how do you get to the filters on a pansonic rear projection pt-50lc14 i have taken the back off...
(More)
how do you get to the filters on a pansonic rear projection pt-50lc14 i have taken the back off cleaned the fan removed the bulb cleaned that compartment still no luck
power light keeps flashing green and wont turn on. how do i fix this.on a 40 '' panasonic rear...
(More)
power light keeps flashing green and wont turn on. how do i fix this.on a 40 '' panasonic rear projection tv model # PT-40LC12
I have red spots all over the screen on my pt-40lc12. It is mostly visible when a white background...
(More)
I have red spots all over the screen on my pt-40lc12. It is mostly visible when a white background is on the screen. Is this an EEPROM error like I have read about other models having?
i went to turn m tv on one day and it doesnt work. it is the pt-40lc12, it said something on the...
(More)
i went to turn m tv on one day and it doesnt work. it is the pt-40lc12, it said something on the screen about cleaning the air filter i did that and then nothing happened. I removed the left speaker cover and that is where the bulb i assume is and it seems like it shattered i guess that means its blown? what do i do and is that even the problem
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
