It may be happen SD card error, you can formatted it and it will re-used again. but do this way, your photos will be lost. you can copy your photos to your laptop. if you have lost your photos without backup. you can recover photos from SD card by hodo photo recovery software, the free download site:
http://download.cnet.com/Hodo-Photo-Recovery/3000-2248_4-75876050.html
SOURCE: memory card cannot read by digital camera.
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - go to format option- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
SOURCE: Nikon S50 camera photos as a black image, no view through LCD
CCD FAILURE !
Call NIKON for FREE REPAIRS it is a known issue ask them about BAD CCD
RATE ME WELL !
Regards
Zohail
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
SOURCE: Card error on Agfa digital camera
Get a card reader (they don't cost much) and download your pics to your computer. Then, put the card back in the camera, go into the menu and scroll to "format" and follow the on-screen instructions. This will erase and optimize your card. My advice, don't leave your pictures on the card for very long...get in the habit of downloading on a regular basis and format the card regularly.
SOURCE: Memory Card Error on my Canon Power Shot S2 15 using Kodak SD car
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
