I have a Simplex L1000 that when you retract the lever from the key side, the latch will not retract all the way causing the door to jam sometimes. On the other hand if you retract the latch from the non-locking side, the latch will retract completely as it should. What could be the issue?
SOURCE: How do I remove a
use the other side of the spanner wrench with the point and insert it into the hole in the inside sleeve and you will feel some spring tension.........push in the tool and pull the handle off at the same time.
SOURCE: can a L1000 series simplex
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
under L1000/Specification/SimplexL1000 Catalogue PDF
SOURCE: Iv'e got a Simplex L1000
Here is a link to the Kaba Ilco web page which has a grid chart, including the L1000 series lock:
Of particular interest to you will be the Manual (page 10) and Parts List, which shows an exploded view of the lockset. Hopefully this will give you the info that you need.
On the same webpage you will also find a link "Contact Us" for further technical information and parts.
Also on that page is a link to get Adobe Reader. If you don't already have it installed on your computer, you will need it to open the PDF files for the manual and parts list.
Hope this helps. Good luck!
SOURCE: The KABA L1000 Simplex lock
I recommend that you contact Kaba Ilco directly with your problem.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
SOURCE: Simplex unican L1000 lock, occasionally the top
