Question about Simplex Kaba Ilco Unican L1000 keyless lock
You need to set a code, turn spanner right (small click) and turn back. Turn outer handle to stop position (latch won't retract). Enter code & turn outer handle again. Lock should be locked at this point unless code is entered.
Posted on Jul 24, 2013
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Good luck--and please provide feedback if this helps!
Posted on Nov 03, 2011
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Apr 06, 2011 | Simplex Kaba Ilco Unican LP1000...
Jan 06, 2011 | Simplex Kaba Ilco Unican LP1000...
Oct 06, 2010 | Simplex Kaba Ilco Unican LP1000...
Aug 11, 2010 | Simplex Kaba Ilco Unican LP1000...
Jul 13, 2010 | Simplex Kaba Ilco Unican LP1000...
Jun 15, 2010 | Simplex Kaba Ilco Unican LP1000...
Jan 21, 2009 | Simplex Kaba Ilco Unican L1000 keyless...
Jul 07, 2017 | Simplex Kaba Ilco Unican LP1000...
652 people viewed this question
