Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
A typical limit looks like this:
Consult your furnace schematic to determine how many of these puppy's are wired in and around the furnace. Make sure they all have continuity. Have the power OFF before you reset the limit. Ouch!
Somewhere in your furnace all of these flashes have a chart you can consult usually located on the backside of the blower cover.
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Thank you for the quick response. My furnace still won't come on. The ground is good and the other wires are connected well. Will try jumping sensors again.
