Question about Goodman Heating & Cooling
Goodman furnace has solid red light what do that mean?
Red light means on but its not doing any thing. how can i tell whats wrong if light not blinking
  • Goodman Master
  • 3,492 Answers
Steady red light means on
Posted on Oct 26, 2017
5 Suggested Answers
buffalonyman
buffalonyman
  • 1865 Answers
SOURCE: my goodman furnace lights runs for 15 seconds and
There is no way to guess what the problem is. I am a HVAC tech, I use a meter to troubleshoot the problem, you need to use a meter and troubleshoiot the problem
Posted on Oct 13, 2009
milten1
milten1
  • 1304 Answers
SOURCE: goodman furnace indicator light flashes four times
this is a overlimit cut out,
whats happening is the internal cabinet is getting too hot, so the system should shut down until that temp drops below safety levels,
this particular problem, usually deals with air flow, your not getting the proper amount of air through the blower.
i would check, your filter here, usually this is the first thing to check before trying any sort of re4pair
Posted on Oct 17, 2009
David Shaub
  • 2976 Answers
SOURCE: Need to find the pressure switch on my goodman furnace
It's mounted onto the gas valve. It will be a button or lever that you have to push in or down, depending on the style.
Posted on Nov 20, 2009
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: My Goodman High efficiency furnace stopped working
On the panel with the wiring diagram, there is an error code chart. I think 3 flashes is a pressure switch problem. Check your air filter, condensate pump or hoses. Check the small hoses going to the pressure switch, check your air intake and exhaust vents. Remove any moisture or debris. Make sure all venting pitches back to the heating system and no low spots are holding water.
Posted on Dec 11, 2009
Anonymous
  • 25 Answers
SOURCE: goodman furnace model # GMNT100-4B
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Posted on Mar 24, 2010
My auto limited slip differential light and check engine lights are blinking red on my 2012 Toyota rav4. What does that mean? And how do I make them turn off?
The check engine light tells you that the computer has detected a problem. Take your rav4 to your local parts store, most will read the codes for free. The codes pretty much tell you what's wrong.
Jun 12, 2015 | Toyota Cars & Trucks
I have an Olsen furnace. It's not running and there is a red light blinking. What's wrong?
Count the blinks in between pauses. On the door of the furnace will be a legend that tells you what that number of blinks mean. For instance 3 blinks may mean open limit switch or pressure switch failed to close, something like that. Post here what it tells you then we can help.
Mar 23, 2015 | Heating & Cooling
What does two blinking lights mean?
It depends on which 2 lights are blinking. Samsung uses a combination of blinking lights to tell what's wrong; sometimes it's 1 light; sometimes it's 2; sometimes it's 3 (or more), but we need to know what lights are blinking to tell what's wrong.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 27, 2015 | Samsung 24 In. Stainless Steel Built-In...
Hi, what is the flashing light on my HTC wildfire screen ? sometimes it's flashing and sometimes not so could you please tell me how it works normaly ? thank you
i think you mean the led above the screen. it is a led that means a lot of things
like: orange - recharging green - full battery red - low battery
there are more things like notifications for text messages (all apps can make ir blink for their own reason)
hope this helps
Feb 20, 2011 | HTC Wildfire Cell Phone
Red led power light comes on, then flashes. no picture or sound motherboard problem?
Count the number of flashes. The number and sequence will tell you what's wrong with it. It will self diagnose and give you what we call blink codes. Google the make and model with words blink codes and it should tell what they mean.
Jan 22, 2011 | Panasonic TH-42PX75U 42 in. Plasma...
My M30CF AC unit is blinking green and red twice and then red by itself 3 times. then repeats. My air conditioner is shutting off randomly and doing this. Can you tell me what the problem is?
If you have the manual for your unit... look in the troubleshooting section and see what that combination of lights means... those lights are flashing a code at you telling you what is wrong...
When you get the explanation, then comment back and tell me... I may be able to help correct what is going on then....
BTW, did you try to recycle the power to see if it goes away???
heatman101
Nov 15, 2010 | Friedrich M30CF Split System Air...
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
My blackjack 2 blinks yellow when i plug in the charger. it wont charge. theres nothing wrong with the phone that i can tell and when i checked the white dot it was red but it never got wet. its working...
when that white dot is red it means moisture of some sort got to the battery and mean the battery the damaged the light means the battery is charging abnormally so the best thing is ti get a new battery try ebay they are cheap hope this was helpful:)
Oct 19, 2009 | Samsung BlackJack II Smartphone
Red light is blinking. Do not know why. How do I
Unfortunately, only way to see the error codes you have to get the printer to give you a green light so you can print out the configuration page. Far as the red light blinking, there could be a number of things it could be.
First, make sure the toner cart is installed correctly
- Check to make sure that there is paper in either the pull out for fold down tray.
- Check to make sure that there isn't a paper jam. Remove the toner cartridge and check to see if there is any paper stuck inside.
If you get the green light after checking those things, press both buttons down for about 2 seconds and release. On the configuration page there will be a set of numbers that indicate what the error codes are. If you can get me that information I can tell what they mean.
Aug 03, 2009 | HP LaserJet 2100 Printer
Status Light is red and blinking - Laser Printer
it means that one of the componets in the printer need replacing it could be the waste toner container. have a look at the on screen display that you get when the printer is operating
to access in windows XP go to the clock corner of your screen
you will see icons
find the one that is for the clp300 click on it and the on screen display will appear
look at the informaton and it should tell you whatt is wrong
Mar 31, 2008 | Samsung CLP 300 Laser Printer
Heating & Cooling Logo
2,135 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Brad Scarpetta
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
