SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
SOURCE: Capillary tube replacement
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
SOURCE: Our water line on the refrigerator is leaking? Can't find the shut off valve?
most are located under the sink,so are located behind the frig.-mike
SOURCE: condensation inside the refrigerator on the corner/roof
you need to defrost the fridge by switching it off for atleast 8 hrs.
