SOURCE: My xbox 360 keeps on restarting
hit the bution by the on bution and in dack of the controlor
SOURCE: My xbox 360 keeps on restarting by itself
Putting out a simple solution, try using a brand new faceplate. Myabe your faceplaye is restricting your console.
SOURCE: Xbox 360 disk tray wont stay shut
http://www.youtube.com/watch?v=xEGKDGPj1iw
watch that it will solve the probelm i had it and it works fine now
hope it works for you to
SOURCE: XBOX 360 green light flashing....
Its the drive. Most of the problems with the drive not opening is the belt slipping inside. If you can find a new belt for the motor then change it. Otherwise I would Swap out the board to the new drive and it should solve your problem.
SOURCE: My xbox 360 won't read my disks
if it does this with all the disks then your drive is either 1.drive is bad 2.firmware is corrupt. i would assume that your drive is bad, unless you have tried to hack your drive firmware and corrupted it. if you did try and hack the drive send me an email at [email protected] and i can tell you how to reverse it.
