CD or Tape will play for a few seconds and shuts off. It has to do with Timer, I assume, but I cannot shut off the timer. The timer light is on (red).
SOURCE: help
No, I doubt if the surge device is causing your problem. most likely there is a power supply issue, or a fauly with one of the servo or motor driver circuits. This is not a repair or a quickie fix for the end user I'm afraid. This unit is going to need to be taken into a repair shop to be diagnoised. Good Luck
SOURCE: Unit runs for 59 seconds and shuts off
This is a problem in one of the damper-related components, most likely the switch or motor, but it may also be the motor or the damper door.
The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
You can find a helpful exploded view by entering your model number here: http://www3.sears.com
SOURCE: cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
SOURCE: sharp 5 disc cd player
Email i got from Sharp:
I do apologize for the problems you are having with your audio unit. The protect mode
indicator will appear when the unit detects abnormal resistance in your speaker setup. I
recommend removing any additional speaker wire that may be added to the unit to extend the
factory speaker lengths. Also, make sure you have all the factory speakers attached, and all
non-factory speakers removed. Finally, please unplug you unit from he wall for 1 hour after
checking all of the above suggestions to completely reset your unit.
If you are still having issues after doing all of the steps mentioned above, the unit may need
to be evaluated by a Sharp Authorized repair center.
SOURCE: Memorex Model MD6451R CD play - LCD readout "hold"
Looking down on the unit from above with "Memorex" reading left to right look at about one oclock. There is a switch marked hold ...turn it off. Its black on black, so its hard to see. It disables the onboard controls. The remote if you have it works either way, but when on hold it will act just as you describe.
