Make sure the hold/lock is not engaged Try another USB port Reset the player If that fails: Download the newest version of the Philips Device Manager: www.usasupport.philips.com - change your country/language as needed Enter in your exact model # Click on the link for your exact model # Click on the Software & Drivers section Click on "Firmware Upgrade Software" Install the new Device Manager Open and run the "Repair" tab If still nothing: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty. -Tha Mp3 Doctor
WARNING: this process will erase all songs off the GoGear. Disconnect the GoGear from computer. Turn the GoGear off. Hold in the volume + button. Reconnect the GoGear while holding in the volume + button. Continue holding the volume + button. After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now). Good To Go (Gear)! -Tha Mp3 Doctor
Reset the player first by inserting a small paperclip or other device into the rest hole and holding for several seconds (when the player is turned on).
If that fails: Make sure you back up all songs on the GoGear before attempting this solution. 1) Back up all files on the GoGear 2) Open up Philips Device Manager (Start --> All Programs --> Philips) 3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button 4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard). -Tha Mp3 Doctor
There is a new version of the software for this device on the Philips website - www.usasupport.philips.com - let me know if this works for you - just added within past week.
If it fails to resolve the issue, reply to me - I have a few other ideas.
Try transferring with Windows Media Player instead - see if the GoGear icon appears on the left hand side of the WMP screen (while the GoGear isp lugged in). If it does, then you can transfer and delete songs through Windows Media Player.
Back up your files on the device, if possible and then perform a Repair (warning: this will delete all files from your GoGear): Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new. You will now be able to load the firmware upgrade that makes it compatible with Vista. open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the Update tab. The Firmware upgrade will take place automatically, and should resolve the issues you have been having.
