20 Most Recent
Philips HDD065 MP3 Player Questions & Answers
Hi I am currently using windows vista and am
Hi, I had the same problem since I bought a new laptop with vista. And finally today I found the software!!! So it was 6 months with the same music. Software is calling Herbert and its working on my computer with vista. I hope this going to help you.
link
http://wareseeker.com/screenshot/herbert-1.0.exe/449482
My HDD065 will not charge and is not recognised by
If you let the battery get too low, the battery will not charge because the motherboard does not have enough power to control the charge process. There are two ways to fix this. 1) buy a new battery that will be supplied fully charged. 2) borrow a friends HDD065, fully recharge the battery and remove it. Place the battery in your player and turn it on. Put your player on charge. Without turning your player off or removing the charger, remove your friends battery and place yours in it. It may take a couple of attempts but you should be able replace your battery and keep the player operational. Leave your battery to fully charge.
How Do I Restart my Philips MP3 Player??/
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Update using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Hdd065 has frozen
Try another USB port
Reset the player
If that fails:
If still nothing:
-Tha Mp3 Doctor
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two
seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote
control blinks twice. If the light blinks once only, recheck the code for your
brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV
switches off, press select. The light on the Sky remote control blinks
twice (code stored). If your TV does not switch off, press tv, then
press the standby button. Repeat this (press tv, then standby)
until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all
possible codes for that make of receiver have been checked. Repeat from step
one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control
setup process is complete. If you did not see the TV Guide screen, you must now
complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two
10. Key in the number of the channel on your TV that you use for watching
satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The
remote control setup process is complete.
Philips GoGear 8GB wont show song titles or artists.
the phillips go gear mp3 player is a total pice of **** the best thing you could do is go out return it and buy a sandisk sansa other wise called a sansa fuse they are great and they have an expandable micro sd card port.
oh and to fix your phlips go gear mp3 player you need to take a pin and stick it in a small hole on the side i belive it is on the left side next to the mic.
Reading
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Need help
The system files on the player have been corrupted or deleted.
Install and run the Philips Device Manager form the product CD.
Connect the player to the mains and the PC.
Select the repair / restore option and follow the on-screen prompts.
This will format the player and restore the system files.
NOTE: The HDD065 is only compatible with Windows XP and Windows Media Player 11.
Battery for GoGear HDD065/05
Hi, you can get a battery on ebay, there is another solution if you know someone with the same player. The player will not charge or start up if the battery gets too low. Borrow a friends player HDD 065 / 075. Remove their fully charged battery (make sure their player is off) and place it in your player. Switch on the player (should work now) and plug in the mains charger. Without turning the player off or unplugging the mains charger remove your friends battery and replace yours. Leave the player to charge the battery until full. This should solve your problem provided your battery is flat and not damaged. Do not place the flat battery in your friends player as this can cause problems if they have upgraded firmware.
Player + radio hdd kt 0043001137
Need more information, but try this:
There are a few different possibilities.
1)Your subscription to your digital music service such as Napster, etc has expired. Sorry - unless you renew your subscription, you will not be able to play these songs again.
2) Your songs have DRM-encryption on them. To check and see, right click on an individual song name in Windows Media Player, and click on "License" or "Digital Rights"; if the affected songs have DRM encryption, then get DRM-removal software.
3) Your songs do NOT have DRM-encryption on them. In this instance, follow the procedure for item#2, except click on the link in the License or digital Rights tab that says "acquire license" (make sure you are connected to the internet first).
-Tha Mp3 Doctor
Philips gogearhdd065/05
Try transferring with Windows Media Player instead - see if the GoGear icon appears on the left hand side of the WMP screen (while the GoGear isp lugged in). If it does, then you can transfer and delete songs through Windows Media Player.
-Tha Mp3 Doctor
Restore
you can do it with device manager
