HP Deskjet 6980 InkJet Printer Logo
Posted on Mar 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blinking orange light
There are two look alike symbols that look like light bulbs and the left one is blinking and the printer will not print.
Anonymous
Level 3:
Genius:
  • Master 1,142 Answers
  • Posted on Mar 24, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1142
Questions
6
Helped
444594
Points
3128
Printer lights blink in certain patterns to tell you about specific problems.
open this link and resolve the issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00575443&lc=en&dlc=en&cc=us&lang=en&rule=26028&product=467982
I have a triangle error symbol in the lower right hand side of my printer, it has a lightning bolt inside of the symbol........what does this mean?
Canon printer light blinking error is a common error. Each printer features a flashing light to indicate its functionality. With Canon printers, you have flashing green and orange lights to inform you of any existing problems. It is suggested to carefully observe the number of flashes or the pattern of blinking lights as this will help you to understand the problem. And depending on the pattern, you can follow our canon printer troubleshooting guide mentioned below to solve that issue.
What does triangle with lightning bolt mean on Canon printer?
The orange triangle with the lightning bolt comes on when the printer is plugged in. The white light above the power button is on, but the printer is otherwise dead.
What does the orange triangle mean on my Canon printer?
When a printer error occurs, the Alarm lamp flashes orange as shown below. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error. Power Lamp Flashes Green.
What does the triangle symbol mean on my canon printer?
Seeing a yellow triangle with an exclamation mark usually indicates that a hardware device needs to be updated. If you are seeing the mark in Device Manager, we recommend checking the device status of the printer driver.
What does the flashing yellow light mean on Canon printer?
When an error occurs in printing such as the machine is out of paper or paper is jammed, a troubleshooting message is displayed automatically. Take the appropriate action described in the message. When an error occurs, the Alarm lamp flashes orange and a Support Code (error number) is displayed on the computer screen.
1helpful
Upside down orange light bulb on the right side is blinking. small white logo is also blinking beneath it. It will not print. The print cartridges are new. The are not generic. I have rebooted and un...
When the camera is connected correctly, the Connection light is illuminated. The Connection light blinks green when printing from the camera. If the camera is not PictBridge-compatible or is not in PictBridge mode, the Error light flashes.
2helpful
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
2answers
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
1helpful
The caution symbol blinks orange wherever the
One of the things you could [if you havent already tried it] is turn off the printer and disconnect the AC Power cable. the press and hold down the power button for, about 30 seconds then release it. After that reconnect the power cord and turn on the printer. this process should have reset it
Changing ink cartridges
hi! there might be two possibilities...
1) the device drivers you have installed is corrupt.. try uninstalling n then installing the drivers
2) if that is not working out then your printer must be having some problem.. you may have to get it serviced.
932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Left light blinks and i can't print anything
Open the cover of the printer, carriage will move out. Upside it you see a yellow arrow showing to on of 5 symbols. Left symbol means empty color cartridge, second symbol means empty black cartridge
k24674
Grand Canyon Tech
Grand Canyon Tech
